mrextreme12 1 Posted July 16, 2012 so everything has been working great for the last couple of months so to i go to cut a nice size banner 23.5 x 4ft and the cutters cuts real good for the first couple mins and then stops the screen says waiting and it just dont do nothing for 10 mins at all i have a creation pcut flexi software what could this be and how can it be fixed? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 16, 2012 If you are on USB connection, change it to a Keyspan or serial cable. 2 Share this post Link to post Share on other sites
mrextreme12 1 Posted July 16, 2012 will this 100%percent correct this skeeter? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 16, 2012 I can't say it will correct you problem 100%,, There are many different variables that will cause your problem.. But definitely a place to start. Serial is always the best connection, And you can read that hundreds of times on this board. Seeing as how you are also using Flexi of some version also try this.. Do yourself a favor ,and change the packet size in Default job properties. Here is how to get there" Just type something on you layout screen Click cut/plot, you cutting screen will come up at upper left hand corner, Click that PROPERTIES box, screen will change, and you have 3 tabs at the top. Click the one that looks like a blade screen changes, Half way down is PACKET SIZE. ERASE what is there, AND PUT IN 1000 KB Then change CURVE QUALITY TO MEDIUM,, CLICK APPLY AT BOTTOM AND OK This seems to give more memory. Also, it is best when you cut something large, to turn your cutter off and back on. To dump the memory from the previous order, It seems to work. Share this post Link to post Share on other sites
mrextreme12 1 Posted July 17, 2012 i went to that screen and it has a tab that look like a piece of paper with a green arrow and something that looks like a com port Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 17, 2012 I have 8.6 but it looks like this go thru the tabs until you find a screen that looks like this, or close. There is a bit of different between the versions, but nothing major difference.. Share this post Link to post Share on other sites
mrextreme12 1 Posted July 17, 2012 ok i found it and i will let you know how it works out thanks skeeter Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 17, 2012 ok i found it and i will let you know how it works out thanks skeeter LOL you do know you can change the font size RIGHT?? Oh my.. Share this post Link to post Share on other sites
