muibubbles 2 Posted May 15, 2012 So the 2 programs i currently use are inkscape and SBE. In SBE there is a weld function that connects the lines to make them one. I was wondering if there was a function like this similar in inkscape? Basically when i outline an image, i have multiple lines and i want to combine them into one line (ive tried the "combine" command but thats really only "grouping" not actually fusing the lines together) Share this post Link to post Share on other sites
muibubbles 2 Posted May 15, 2012 path+ union deletes some of my lines, it hasnt worked =( Share this post Link to post Share on other sites
Jay2703 704 Posted May 15, 2012 Does Path + Combine get what you are looking for. The options under Path are going to be your choices for doing what you are looking for. Share this post Link to post Share on other sites
muibubbles 2 Posted May 15, 2012 Path and combine just "groups" it like one piece but doent treat it like one solid line. I am trying to trace a bumper and i made it in multiple passes. now i want to fill it in with a color but i get all kind of unknown geometry. i ended up removing all the details (headlights and vents) then union worked.. then set the details on the layer on top. I guess there is no real easy way to do it since i drew the whole thing out already lol. thanks jay! Share this post Link to post Share on other sites
muibubbles 2 Posted May 16, 2012 maybe this will help, lets say i make 3 seperate lines (like a U) and i want to join them together to make one continuous line, how do i do that? i tried path> union and it makes a box inside the "U" Share this post Link to post Share on other sites
Jay2703 704 Posted May 16, 2012 Union is meant for shapes, not lines. If you offset the lines then use Path + Union, I think you get the affet you are looking for. http://screencast.com/t/fKENjHlHzjn Jay Share this post Link to post Share on other sites
JP Auto N Design 36 Posted May 18, 2012 Path >combine. Then click the node icon. Go to each corner where the two lines meet, select the end node of each seperate line . Now choose either "join selected nodes" or "join selected nodes with new segment", whichever one suits what you are doin. Share this post Link to post Share on other sites
