horse power graphic 0 Posted January 9, 2012 I saved my first vector as a esp is that correct for singcut pro. How would I reopen it in inkscape to do more work if i had to or do i have to save it as a different file. Thanks Share this post Link to post Share on other sites
mars 45 Posted January 10, 2012 .eps is one vector format - Don't use signcut - but I imagine it can use .eps files. As to working on a file again in Inkscape I always save anything I do in .svg as well as exporting to .eps - since InkScape can export but not import .eps (at least the version I am using) I would then use the .svg version to modify and resave the results in both formats. -Mike Share this post Link to post Share on other sites
BLUEFIRE9x 1 Posted January 10, 2012 I agree above. It is always worth the few seconds to save in a few other files formats. Just in case you want to change anything 1 Share this post Link to post Share on other sites
