Guest stunad, jr. Posted February 9, 2008 Hi, Im new to this forum. Ive read a lot but this is my first post. Kind of a "sandbagger" if you know what I mean... How do I shut off "live update" on sign blazer? Everytime I open the program this comes on and is getting a bit annoying. Is there a setting somewhere I can manually update? Or have it update once a month and not every time? Thanks! Share this post Link to post Share on other sites
firemalt 10 Posted February 10, 2008 It should auto update anytime there is a new version released... not everytime you open the program. Are you sure you are installing the update, and not just downloading it? Share this post Link to post Share on other sites
Mark SignBlazer Support 0 Posted February 11, 2008 Yes liveUpdate should only run (automatically) once a month. This issue seems to affect a small number of Windows Vista users. The simple workaround is to edit the shortcut that you are clicking on to run the program, change the file it is trying to run from sb.exe to sbnt.exe . Then if you want to run LiveUpdate manually at any time, select it from the Help menu in SignBlazer Elements. Share this post Link to post Share on other sites
Guest stunad, jr. Posted February 12, 2008 Yes liveUpdate should only run (automatically) once a month. This issue seems to affect a small number of Windows Vista users. The simple workaround is to edit the shortcut that you are clicking on to run the program, change the file it is trying to run from sb.exe to sbnt.exe . Then if you want to run LiveUpdate manually at any time, select it from the Help menu in SignBlazer Elements. that was the problem, EXACTLY. I changed it and the program opens quickly without the live update. Thanks for the help!!!!!!!!! Share this post Link to post Share on other sites
