Dan01801 0 Posted March 6, 2007 HI Everyone, I have the new unit set up etc, installed sign cut, do I know have to install some sort of driver etc to make it function. I also recieved a small CD in the packet is there something I should be doing with that LOL, sorry for all the questions Thanks Share this post Link to post Share on other sites
thredz 1 Posted March 6, 2007 The small cd is the usb driver install disk.You only need to use it if you are running through usb.If you have it set on an lpt (printer port) you can go in to signcut,go to settings and select the cutter model and lpt as the device.It should work.If you are going to install the usb drivers you will have to have someone else help because I have never done the usb install. Share this post Link to post Share on other sites
