graphicjunkie 0 Posted June 21, 2011 I know that this is a question instead of an instruction...but I still felt it was the best place for it. I'm pretty new to the vinyl stuff still. Here's my details.... I have the laserpoint 24" cutter. Exporting out of Adobe CS2 Illustrator into signcut pro. Here's my problem/question.... I've got a customer requesting a large volume of stickers. Nothing fancy....but he wants 60. But I'm having a hard time figuring out how to tell my plotter software that the VINYL ROLL is only 12" wide, instead of 24. I know how to set the start point of the cutter when I cut...that's no problem. But when I try and make mass copies, it wants to cut over 24" from where I hit the start....instead of 12". HOW do I do this? Thanks! Share this post Link to post Share on other sites
Zimmerman 0 Posted June 21, 2011 In SignCut Pro in the Toolbar in the cutter section change the Y setting box to 12" Share this post Link to post Share on other sites
Dragonduster 4 Posted May 25, 2012 or cut it with signblazer and u can put the same design 60 times (there is an option for that) and it will cut them, thats how i cut my 12 2" stickers of a 24" vinyl Share this post Link to post Share on other sites
Jay2703 704 Posted May 25, 2012 In SignBlazer select Cutter, then Setup. This is where you set the vinyl width. Share this post Link to post Share on other sites
