Dipstah 0 Posted January 27, 2008 Hello, I am new to signBlazer and am trying to edit a EPS file that I imported and saved as a signBlazer file. I am unable to edit this file to change the text. This is a Baseball eps file that I downloaded from these forums. Thanks in advance Mike baseball.SBD baseball.eps baseball.SBD baseball.eps Share this post Link to post Share on other sites
Jay2703 704 Posted January 27, 2008 Try this one. When you import to signblazer your text gets converted to curves. I did a Arrange + Split objects and erased the text. I had to do a Arrange + Weld and Punch Through to punch the white part of the baseball through the black. Then erased the now gray ones. Then I added the text back in. You can change the font if you want. To curve the text I created the text then did a Text + Fit to curve. baseballhelp.SBD Share this post Link to post Share on other sites
Dipstah 0 Posted January 27, 2008 Thats awsome. Did you do it all in SB? I am reading over the manual now Thanks Mike Share this post Link to post Share on other sites
Jay2703 704 Posted January 27, 2008 Yes, I did it all in SignBlazer. It took me a little time to figure things out but I really like the program. I have Adobe Illustrator and some other editing programs but I find I can do most everything with the basic version of SignBlazer. It is really what sold me on the USCutter in the first place. I was ready to spend about 3 times what I did on my PCut but the other guys software wouldn"t do nearly as much as SignBlazer. To get software that was even close to SignBlazer Elements I would have had to spend an extra 4 to 5 hundred dollars. Share this post Link to post Share on other sites
eharris 0 Posted March 30, 2008 I have sign cut and I cannot figure out how to edit on the second image "your text" and "your name". Can anybosy help me? Share this post Link to post Share on other sites
Jay2703 704 Posted March 30, 2008 Here it is in .eps fromat. Just erase the text and replace with your own. BaseballHelp.EPS Share this post Link to post Share on other sites
eharris 0 Posted March 31, 2008 Okay, I feel real stupid because I can't figure out how to erade the text and put my own in. Is there an easy way to tell me how to do it? I need the nuber 2 on the ball and the name "Christian" above the baseball. I have tried to figure it out but to no avail and I need it ASAP. Share this post Link to post Share on other sites
Jay2703 704 Posted March 31, 2008 Is this what you are looking for? BaseballHelp.EPS Share this post Link to post Share on other sites
eharris 0 Posted March 31, 2008 Thanks a bunch. How can I do that? Share this post Link to post Share on other sites
Jay2703 704 Posted March 31, 2008 What cutter software do you have? You should be able to delete elements and add text with whatever you have. Share this post Link to post Share on other sites
eharris 0 Posted March 31, 2008 I cut in Sign cut, I have AI (very novice..haven't figured it out yet) and I also have inkscape. Share this post Link to post Share on other sites
