Godissewgood 0 Posted May 18, 2011 I need to cut out stencils for someone wanting to paint text on rough board. (Doesn't think vinyl will stick to it). If so what material would you use and what blade size? Thanks for any help I can get here. Share this post Link to post Share on other sites
Leonard 0 Posted May 19, 2011 I used my us cutter laserpoint 24 with adhesive vinyl to make a stencil with words.. I used a regular blade, normal pressure. Cut normal(no reverse), and weed. Share this post Link to post Share on other sites
AbsoluteAirbrush 33 Posted May 19, 2011 I'm an airbrush artist and do this all the time, use Oracal 813 spraymask for flat surfaces or 811 I think it is or 810 for rounded surfaces like helmets, tanks etc. Normal pressure and blad settings. It's pliable and flexible like sign vinyl but is made for your application. Hope this helps and GL, Alam Share this post Link to post Share on other sites
