Billie 6 Posted May 12, 2011 Good morning, I have question about which vinyl is the best to use on a wood sign for outdoor use, The wood will be painted. Also Do I need to put a clear coat over it ? Thank u Billie... Share this post Link to post Share on other sites
tekcorps 50 Posted May 12, 2011 If the painted wood surface is smooth I would go with Oracal 751. For durability you could clear it, not necessary. Or you could go with Oracal 651 and clearing would help the durability. Again probably not necessary. If you are in the wet part of the state, the sign will probably be washed every 18 months or so! A clear might be considered. Share this post Link to post Share on other sites
