laserman70 2 Posted January 24, 2008 Lookied on the forum, I cannot find it. I am looking for the location of the chip on a refine 721. I know its on the motherboard, where exactly is the motherboard located. I took the right side off and dont see there, so i figured I would ask you guys for help. thanks Share this post Link to post Share on other sites
kenimes 42 Posted January 24, 2008 Tip the cutter on it's side, then remove the right side panel. The motherboard is attached to that panel on the bottm. Should be 6 screws. Share this post Link to post Share on other sites
laserman70 2 Posted January 24, 2008 here is what i have, the chip is half the size of the board. Their is no chip on the board of that size. Share this post Link to post Share on other sites
laserman70 2 Posted January 24, 2008 I found it, for those of you thinking of this, please read. It is the underneath panel that needs to be pulled to expose the motherboard. On the bottom side of the machine, not the right side panel. Take the small underneath panel off and you will see the board. thanks Share this post Link to post Share on other sites
kenimes 42 Posted January 24, 2008 Right... Unless you have an older model, in which case the motherboard WILL be under the right side casing. Share this post Link to post Share on other sites
signman911 1 Posted March 6, 2008 What is the cost for this chip????? Share this post Link to post Share on other sites
Guest Terry Posted March 6, 2008 http://www.uscutterdirect.com/search.asp?keyword=ram&search=GO Share this post Link to post Share on other sites
dustinjtrr 0 Posted September 6, 2008 What would be the major advantage to upgrading? Does it allow you to cut larger more detailed things at faster speeds? Share this post Link to post Share on other sites
kenimes 42 Posted September 8, 2008 Just more buffer memory. Share this post Link to post Share on other sites
freebird1963 11 Posted September 15, 2008 When are these chips gonna be back in stock. Been out of stock for awhile. How do you tell if you have older model or not. And were are the instructions for changing the memory at. Didn't see any in the cheap manuals sent with my refine mh-721 Mark Share this post Link to post Share on other sites
kenimes 42 Posted September 15, 2008 No instructions for changing the chip, sorry. Fairly simple though once the motherboard is exposed. To tell if you have the older or newer style MB, just remove the right side case, and if you see a two tier motherboard with a fan, it is the older style, but if you only see what is pictured above in the thread, it is the newer style. We have some in stock, so not sure why the web site says this, but just call us to order one: 425-481-3555 Share this post Link to post Share on other sites
freebird1963 11 Posted September 15, 2008 Damn I just made a order too. Only pic I see is for the ram itself. No motherboard pic. Thanks Mark Share this post Link to post Share on other sites
Guest Dr_Jeff Posted November 11, 2008 ordered one with my cutter. any uses for the old one ? Share this post Link to post Share on other sites
kenimes 42 Posted November 11, 2008 ordered one with my cutter. any uses for the old one ? No, not really. Maybe as a backup if the 4mb ever goes bad? Not sure... Share this post Link to post Share on other sites
