edge
Text in a column?
Is there a setting in Corel that would enable text in a column similar to the below example.
E
X
A
M
P
L
E
To perform the above display I entered after each character, starting a new row. Is there an easier way that I've yet to find?
That is how I always do it too.  I haven't found an easier way.
You could rotate the text -90, break the text apart, select each character and rotate back to 0.  But then you have to play with the spacing.  too much work.  :notsure:
