gadget1961 5 Posted March 2, 2011 i have a disk with faces on it but they are as one picture on the disk how do i separate them as they are all different , in sign blazer , they are eps files , also how to make more than one to use them if their is only one to use , it comes up on the screen , as whole , if i want to use only 4 of them what do i do with the rest of the others not being used ,would i just move them of the the picture out of the red square thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 2, 2011 i have a disk with faces on it but they are as one picture on the disk how do i separate them as they are all different , in sign blazer , they are eps files , also how to make more than one to use them if their is only one to use , it comes up on the screen , as whole , if i want to use only 4 of them what do i do with the rest of the others not being used ,would i just move them of the the picture out of the red square thanks have you tried select them all, then, ungroup> then just select the ones you don't want and cut/ or delete? I use Flexistarter, and that is the process there. Share this post Link to post Share on other sites
gadget1961 5 Posted March 3, 2011 have you tried select them all, then, ungroup> then just select the ones you don't want and cut/ or delete? I use Flexistarter, and that is the process there. i will give it a try thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 3, 2011 i will give it a try thanks hope it works for you, your welcome Share this post Link to post Share on other sites
gadget1961 5 Posted March 3, 2011 found it out ,, and even found how to multiply the one item for more than once like i need 4 of the same , now im on a roll and it gets easyer every time i try different things , it not that hard , now i have to put it all together and hope i dont !@#$% it ^&&& haha if the lights go out i hit the wrong button thanks for the pointers Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 4, 2011 found it out ,, and even found how to multiply the one item for more than once like i need 4 of the same , now im on a roll and it gets easyer every time i try different things , it not that hard , now i have to put it all together and hope i dont !@#$% it ^&&& haha if the lights go out i hit the wrong button thanks for the pointers great Share this post Link to post Share on other sites
