Nu Image
summa cutter not completing cuts.
Hey all,
  I have a Summa t series cutter. I just changed the blade in it. Now all of a sudden when I am cutting stuff it doesn't complete some of the cuts. It worked fine before I changed the blade. Now it just randomly doesn't complete cuts in different areas of my project. If I cut two of something it doesn't cut in the same exact area on both. Any ideas.
Tony
I just own a Summa too D series but did not changed a blade yet.
Is this blade the original factory blade?
Does the offset is the same?
Paco
That can happen when you get a different blade angle then the one you had originally...  I have to check for the actual angles available, and do not feel like it right now, but I do recall you can get different degree angle blades. There will be somewhere in your software to make needed change in that setting. I do not know where in the package you use but I have it called Plotter compensation. Look for an adjustment for sharp angle or get a manual for the setting area for what software you use.
