ajgarber70 0 Posted September 7, 2010 i was needing to get this in eps where i can cut it or if anyone has a file in eps very close to this thanks i have sign blazer and it is hard for me to do much thanks Share this post Link to post Share on other sites
mark-s 1,126 Posted September 7, 2010 Download inkscape mark-s Share this post Link to post Share on other sites
ajgarber70 0 Posted September 7, 2010 ok i googled it they have a download of 0.48 is that what i need to download thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 7, 2010 www.inkscape.org Vectorising in Inkscape SolutionThis walk through explains the basics of vectorising in Inkscape. Step 1) Import your image. Click File>Import, find your file and click OK. Step 2) Select the image, go to the top of the screen, click Path>Trace Bitmap. Step 3) The Trace Bitmap menu will then open. Here you can select how you want your image vectorised and adjust the settings. You can also generate a preview. Once you are happy with the preview click OK and close the Trace Bitmap screen. Step 4) Now you will have your new vector image and the old raster (bitmap, jpeg, gif etc) image stacked on top of each other. Seperate the two and delete the raster. Step 5) Play around with your new vector image! Share this post Link to post Share on other sites
ajgarber70 0 Posted September 7, 2010 Thanks for the help i'm on dial up and i was downloading it and it said 6 hours then my computer started detecting bad files and stoped the down load so im out of luck thanks for the help though is there a good soft ware i can buy from us cutter that i can use with the laser point and my windows vista that might be the best thing for me to do. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 8, 2010 you can try and vector it in Signblazer. That is free also. download on first page http://forum.uscutter.com/index.php/topic,21665.0.html Share this post Link to post Share on other sites
Soul Reaper 0 Posted September 8, 2010 how about a strait on pick. Share this post Link to post Share on other sites
ajgarber70 0 Posted September 9, 2010 ya here is a better picture of it. signblazer wont even let me import this one in don't know why.it does but my work area is blank with nothing there. thank's i just need help getting it to a eps vector so i can have a chance to clean it up and learn.. Share this post Link to post Share on other sites
ajgarber70 0 Posted September 10, 2010 ok i went in and saved the picture as a bmp file and not a jpeg and i was able to work on the tree alot better that way i think i can do it on my own now. so cool.. now my next question is the font i have been able to match it close but i am thinking the h in hutchison is a diff. font than the rest of the name? am i right? thanks Share this post Link to post Share on other sites
Soul Reaper 0 Posted September 10, 2010 here you go TREE1.eps TREE1.eps Share this post Link to post Share on other sites
ajgarber70 0 Posted September 10, 2010 Thanks you so much.... Share this post Link to post Share on other sites
