cbedge 0 Posted September 6, 2010 I am not able to get this to cut, the lines are all ragged. Thanks Share this post Link to post Share on other sites
wasatchcars 0 Posted September 6, 2010 Here it is http://www.brandsoftheworld.com/search/logo/mundy Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 6, 2010 Have you attempted to re-draw it in Illustrator, etc?....If not, it would be a good one to practice on....Using auto trace it almost completes itself...But on a simple one like that, starting from scratch is easier.... Share this post Link to post Share on other sites
megacab 1 Posted September 6, 2010 just use the file from brands of the world and then re-create the text. very, very simple. here's a hint. the font for the text is baskerville i do believe. a quick search shows that all 9 of your posts have been for help.......all 9 have received help. not one single thank you ever. pretty shitty manners as far as i'm concerned. a simple thanks for the help goes a long way. Share this post Link to post Share on other sites
cbedge 0 Posted September 7, 2010 If you would check you will find that I say thanks in advance. And as far as asking for help I was under the impression that was what the forum was for. So maybe your manners are the one that should be in check. Share this post Link to post Share on other sites
megacab 1 Posted September 7, 2010 as far as the TIA thing....i apologize. at least you say that. i guess i'm just different and would come back on and say thank you AFTER someone helped me so that i could specifically thank them. just 2 diferent ways of doing it. again, i apologize. good luck with the file. Share this post Link to post Share on other sites
