thall17 0 Posted December 29, 2007 I am a totak Noob!!! I can't even seem to install the knife! Is the red cover supposed to lift up more then a little. Anyone that has a Lasercut Please help!!!! Share this post Link to post Share on other sites
haumana 1,221 Posted December 29, 2007 You do not need to access anything under the red carriage cover to install the blade (and holder). Insert the blade into the holder and adjust it so that it just barely sticks out (it took me some playing with the depth to achieve the right about of blade to expose for the proper cutting depth). Insert the blade holder in the collar that is on the rights side of the carriage. The sliver screw is what you use to loosen and tighten the collar to hold it securely in place. You're going to love your LaserPoint when you get it all setup. Good luck. Share this post Link to post Share on other sites
