DIRTRACER 2 Posted August 6, 2010 When heat press printing t shirts do you guy's and gal's press one side one day and the other the next day. Thanks Share this post Link to post Share on other sites
chefgary 4 Posted August 6, 2010 I press one side, turn it over and then press the other. Share this post Link to post Share on other sites
DIRTRACER 2 Posted August 6, 2010 I did that today and first side tryed to stick to bottom of press. Share this post Link to post Share on other sites
mopar691 281 Posted August 6, 2010 need a teflon sheet or craft paper in there Share this post Link to post Share on other sites
hockeygirl 30 Posted August 7, 2010 Don't peel off the transfer paper until you're done with both sides. Share this post Link to post Share on other sites
mr300s 1,272 Posted August 7, 2010 Don't peel off the transfer paper until you're done with both sides. I just did that today worked great Share this post Link to post Share on other sites
designed 0 Posted August 7, 2010 I use siser easy weed and press the front peal the paper off turn it around and press the back right away and never had any sort of issue it works great Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 7, 2010 I use siser easy weed and press the front peal the paper off turn it around and press the back right away and never had any sort of issue it works great ditto Share this post Link to post Share on other sites
screenprintr 319 Posted August 11, 2010 You can also heat press the first side, take the shirt off, open it up and slide the t-shirt on the heat press with the first side going under the heat press and the collar facing you. Than heat press the second side. EZ weed is a hot peel method. We screen print with the collar facing us. That practice helps us align shirts easier with heat presses. Share this post Link to post Share on other sites
