crgraphics 0 Posted July 26, 2010 Hi I just bought a used MH871,two things seem wrong. 1) the reset light stays on 2) the carriage stays down when cutting it does move up and down with the power button. seems I read somewhere if the red reset switch is this will cause this to happen. Am I on track? or is there something else I should check before doing the ticket thing? Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 26, 2010 Was it acting like this before you purchased it? Did you see it cut before buying? Do a search for battery test, and try it. Is the carriage head in the track, the white wheels, are they firmly in their track? Share this post Link to post Share on other sites
crgraphics 0 Posted July 26, 2010 no it was cheap i didn't test it. the reset light stays on. nothing happens if I manually push the red reset button Share this post Link to post Share on other sites
prestonservco 26 Posted July 26, 2010 Pretty sure that's a bad motherboard. Having fried two of them this month on the same model - I'd say your out $90 for a motherboard. Sorry. Do the ticket thing. They offer lots of help to troubleshoot. Just be patient, it takes a lot of time to work through the emails, etc. Share this post Link to post Share on other sites
crgraphics 0 Posted July 27, 2010 works right now was a setting wrong but the reset light stays on is that normal? Share this post Link to post Share on other sites
rrc1962 0 Posted July 27, 2010 works right now was a setting wrong but the reset light stays on is that normal? Yes, it is. Share this post Link to post Share on other sites
