Hoppers
Diagonal Line?
I have a mh721    25" cutter and it keeps making diagonal lines in the cut..... any advice would be great as I cannot finish any designs..... thanks
There are lots of topics on this in the USCutter Refine cutting plotter section.  Do a search on "Slashing", "cuts across vinyl", "Unwated Cuts", etc.  Or just browse through the support section, you will find several posts on this exact subject.
Most have found it to be a static problem.  Turning off the weeding box in your software sometimes helps.  Grounding the plotter to the stand with the supplied grounding wire has fixed mine.
