Guest sciondrgn Posted April 15, 2010 Can i print longer than 19"? I want to do long prints for my kart body and wanted to know is this can do it. 13x44 is the max for the 1100 Share this post Link to post Share on other sites
Guest sciondrgn Posted April 15, 2010 Ok, quick question here. A local bar wants me to make some stickers to put on some plastic cups for a party they're having. They only need them for one night. I have a WF1100 and what would I need to buy (and get here fast) to print a simple image on so i can then put on the cups? Thanks! Jay Depending on the logo you want you could get the precut oval labels http://www.texascraft.com/hps/product.php?productid=16813&cat=255&page=1 They have software on the site you can download to print on them correctly with the template. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 15, 2010 Just got my 1100 today from newegg for 109.00 Share this post Link to post Share on other sites
TruckDriver 0 Posted April 15, 2010 Depending on the logo you want you could get the precut oval labels http://www.texascraft.com/hps/product.php?productid=16813&cat=255&page=1 They have software on the site you can download to print on them correctly with the template. AWESOME! Thanks a TON! Share this post Link to post Share on other sites
boosted 2 Posted April 15, 2010 Just got my 1100 today from newegg for 109.00 got mine yesterday, just waiting on something to print on.... Share this post Link to post Share on other sites
bigjimt 1 Posted April 15, 2010 Epson R-1900 13" wide 44" long Print works great Share this post Link to post Share on other sites
Guest sciondrgn Posted April 15, 2010 Epson R-1900 13" wide 44" long Print works great Edit.. I was thinking of the 1400 which is dye ink, The 1900 uses the UltraChrome Pigment Share this post Link to post Share on other sites
hockeygirl 30 Posted April 15, 2010 Epson R-1900 13" wide 44" long Print works great Only downside on the 1900 is that the stock inks are dye based. For decals that is fine as long as you laminate but for shirts the ink fades after washing. The pigment ink has a better advantage as far as water resistance The R1900 is actually pigment ink, but it does use 7 colors/cartridges, so ink will be a lot more expensive than the WF1100. Share this post Link to post Share on other sites
Guest sciondrgn Posted April 15, 2010 Epson R-1900 13" wide 44" long Print works great Only downside on the 1900 is that the stock inks are dye based. For decals that is fine as long as you laminate but for shirts the ink fades after washing. The pigment ink has a better advantage as far as water resistance The R1900 is actually pigment ink, but it does use 7 colors/cartridges, so ink will be a lot more expensive than the WF1100. Sorry about that you are correct.. I was thinking of the 1400 Share this post Link to post Share on other sites
Guest kenya Posted April 15, 2010 I ordered the 1100 with the pigment ink from Cobra this morning..... will be delivered Monday... woohoo. Share this post Link to post Share on other sites
SandyM114 0 Posted April 15, 2010 Bill. your email never did come through about the printer, but Richard emailed me, so I'm set. If you happened to save the email, will you send it again, don't want to miss any info on the printer... Also, which do you suggest to print on? Rolls or sheets for the transfers....Sandy Share this post Link to post Share on other sites
mr300s 1,272 Posted April 15, 2010 Bill. your email never did come through about the printer, but Richard emailed me, so I'm set. If you happened to save the email, will you send it again, don't want to miss any info on the printer... Also, which do you suggest to print on? Rolls or sheets for the transfers....Sandy sorry about that I had big trouble with my email around then and lost everything so I am not even sure what I had sent. Glad to hear you hooked up with Richard he will guide you in the right direction. I have been using sheets of the JPSS paper. I haven't tried anything else I figured I am getting such great results why try something else. Share this post Link to post Share on other sites
SandyM114 0 Posted April 16, 2010 is the 8 X 11 the best size sheets to get? My heat press is only 15 X 15. Or is it more economical to get the larger sheets and print out 2 transfers per sheet?Sandy Share this post Link to post Share on other sites
mr300s 1,272 Posted April 16, 2010 is the 8 X 11 the best size sheets to get? My heat press is only 15 X 15. Or is it more economical to get the larger sheets and print out 2 transfers per sheet?Sandy no you are better of with the smaller you don't really save any money on the big ones that I am aware of. I have only used a couple of the big ones but I have a 16 X 20 press but have found the smaller size seems fine... Share this post Link to post Share on other sites
bigjimt 1 Posted April 17, 2010 My R-1900 Gives me a lot of print.........7 but you only replace what you use........ I have been very happy with my 1900 but to each his own........can't all like the same thing Share this post Link to post Share on other sites
pyrophire 0 Posted April 17, 2010 My R-1900 Gives me a lot of print.........7 but you only replace what you use........ I have been very happy with my 1900 but to each his own........can't all like the same thing Incomplete thou.... message is confu....... what? Share this post Link to post Share on other sites
