fracsuperstar421 0 Posted March 29, 2010 doing a racecar did all the sponsors and little graphics worked great went to do the long side graphic (10 feet long by 20 inches wide) and when it rolls the vinyl through to start to cut it goes to the exact same spot on the vinyl no matter what sie or color i do (its two layers) it starts right in the middle of the graphic and cuts a straight line to the bottom corner and them cuts the rest. it cut the graphic perfect only thing is that line cut through the one end.. i checked everything.......no other color in design no extra node i can't see anything wrong jujst seems to start right there not sure why and help would be great!!! i am using coral to design and signblazer to cut and cutting with a mh 721 thank you Share this post Link to post Share on other sites
jfought 120 Posted March 30, 2010 when you start to cut make sure that you zero your cutter. on my pcut is the button with the cross hairs. Share this post Link to post Share on other sites
hockeygirl 30 Posted March 30, 2010 could be static... is your cutter properly grounded? And if your environment is too dry, it could add to the static problem Share this post Link to post Share on other sites
fracsuperstar421 0 Posted March 30, 2010 yes it is grounded it seems to only be on long cuts Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 30, 2010 problem with static is more on long cuts - also on the copams their was a problem with the dreaded line of death similar to this and the fix was to go flexi starter Share this post Link to post Share on other sites
