Sandblaster 0 Posted March 26, 2010 Trying to get the USB-Serial driver working in Ubuntu Linux for the FDTI USB to Serial port on my newly purchased PCut CT630. Have downloaded the driver from the FDTI driver site 'http://www.ftdichip.com/Drivers/VCP.htm' and followed the instructions to build the driver, remove the standard module then tried to install the new module. The driver does not compile successfully. What do I do to make it compile successfully? Do I need to recompile the kernel with some missing module(s) ("sources matching the current kernel to be installed on your system" from README.dat)? Is that why there are so many make errors? I am noticing that the make command is not finding a bunch of files, a bad link? -------------------------- Errors during the make process: $ make cc1: error: /lib/modules/2.6.31-20-generic/build/include/linux/modversions.h: No such file or directory In file included from /lib/modules/2.6.31-20-generic/build/include/linux/kernel.h:11, from ftdi_sio.c:251: /lib/modules/2.6.31-20-generic/build/include/linux/linkage.h:5:25: error: asm/linkage.h: No such file or directory In file included from /lib/modules/2.6.31-20-generic/build/include/linux/kernel.h:15, from ftdi_sio.c:251: /lib/modules/2.6.31-20-generic/build/include/linux/bitops.h:17:24: error: asm/bitops.h: No such file or directory In file included from /lib/modules/2.6.31-20-generic/build/include/linux/kernel.h:15, from ftdi_sio.c:251: ... tdi_sio.c: In function Share this post Link to post Share on other sites
tinaski 11 Posted March 28, 2010 http://ubuntuforums.org/showthread.php?t=885768&highlight=FT232+USB-Serial is this you http://ubuntuforums.org/showthread.php?t=1433016&highlight=FT232 last post makes it sound like its going to be hard to make it work we use a graphtec and its awsome Share this post Link to post Share on other sites
tinaski 11 Posted April 10, 2010 http://www.inkscapeforum.com/viewtopic.php?f=31&t=4987&p=0&e=0&sid=79599dc7b7e98cf5489f7a2c4b12b2ea try this one it will cut directly from inkscape Share this post Link to post Share on other sites
