paulzeee
Sign Cut Help
Currently i have been using signblazer for when i want to cut fonts...i want to use only signcut but i don't know how (for fonts. I can do vectored stuff)
How are you experience peeps cutting fonts with signcut??
To Cut fonts in Signcut if you are using the windows version you may do simple layouts directly in Signcut using the windows text editor by clicking on the T tool on the signcut toolbar on the left side of the main Signcut window. However the text and layout feature is limited and we recommend you use either Illustrator, Corel Draw or enen the free open source solution inkscape and then use the send to Signcut plug-in to actually send your files for cutting.
