ff-extreme
doing a wrap on a fire helmet
I'm looking for a little guidance, I have done a vehicle wrap in the past and I use Oracal's Orajet 3551G when I do. I was asked to do a wrap on a fire helmet. This thing is kicking my butt! I guess the small size and the shape is what the problem is. I was looking for any suggestions as to tips and stuff on how to handle it. I did a search for videos for wrapping a motorcycle gas tank as I assume it would be similar but didn't find any. Has anyone done a helmet of gas tank before?
helmets are like the hardest thing you could ever try to wrap perfectly, thank god it isnt a motorcycle helmet you are doing
I read somewhere (but haven't tried it) to attach the vinyl to a hoop slightly larger than the helmet and push the helmet through it.  Sound crazy to me but I've heard it works.  Looks like it would stretch it alot but I guess you will have to strech it to get a flat piece on a round helmet.  Has anyone else heard of this?
That sounds like a good idea.  Maybe also use a hair dryer to warm the vinyl and help press it down.  I would also probably use some 3M Primer 94 in the roots of the bends to keep it from pulling up.  Might take a few tries...
Obviously, I wouldn't recommend they actually use this helmet..
Fire helmet = fireman's helmet?
If so, my concern would be how the wrap would hold up if used in the line of duty. Catch fire, melt etc...
Thanks for the ideas Ill have to play around and report back. The helmet would not be used in th line of duty it is a collection piece.
A friend of mine does loads of helmets He masks the small print and such
airbrushes the rest then clear coats the works very sweet work here is a link
http://www.axegraphics.ca
Good luck :huh:
Keith
