beaker 0 Posted November 15, 2007 OK, so I can't seem to get this right. I've been working on a progect and the only way I can get it to work was build it in halfves and the duplicate, mirror, and then try to combine the 2 images. Here is my problem. I can do the first part of both of those, but when I go to combine them and cut them, they get cute as two images side by side. I Need these both to be cute as one image. Can anyone help?? Thanks Tim Share this post Link to post Share on other sites
Kimon 1 Posted November 15, 2007 Might post the file and then I am sure someone will give you some help. Share this post Link to post Share on other sites
beaker 0 Posted November 15, 2007 Any idea on how I can post the file?? Share this post Link to post Share on other sites
beaker 0 Posted November 15, 2007 ok, I got it. It can be downloaded here. www.seductive-engineering.com/signblazer/08_xB.SBD This is the file I've been trying to cute, and its cutting both images, and not one image like I prefer. Share this post Link to post Share on other sites
dgreenh 9 Posted November 15, 2007 What do you use to open a .SBD file? Is that a Signblazer extention? Nothing I have will open it to look at it. Share this post Link to post Share on other sites
beaker 0 Posted November 15, 2007 That is the acutall SignBlazer file. Here is something else. Share this post Link to post Share on other sites
Guest sciondrgn Posted November 15, 2007 When I open these in SignBlazer all I have is two objects both of them squares and grouped together as one object,.. is there supposed to be something actually in the file or just those two squares? Share this post Link to post Share on other sites
beaker 0 Posted November 15, 2007 2 modified squares that I need to combine as one long object. Share this post Link to post Share on other sites
Guest sciondrgn Posted November 16, 2007 I may not be understanding exactly what you are wanting.. When I open your SBD file I see the two objects and they are already grouped together. I go to Cutter and I still see both objects side by side to cut in one pass Share this post Link to post Share on other sites
beaker 0 Posted November 16, 2007 Yes. but if you cut them, they will cut as separate squares. I need to keep that from happening. Share this post Link to post Share on other sites
tservice 3 Posted November 16, 2007 Select your items, click arrange then weld then total weld. Share this post Link to post Share on other sites
Guest sciondrgn Posted November 16, 2007 On my side if you Total Weld the object disappears as it sits in the file. If you ungroup then use the Combine Objects rather than group option. then do the total weld I get one single polyline to cut Share this post Link to post Share on other sites
tservice 3 Posted November 16, 2007 Scoin your right I stabd corrected. Share this post Link to post Share on other sites
