rock jeep 1 Posted December 16, 2009 How can I keep this lil guy in full detail so I can cut the different colors separately. I know there is a way I just cant figure it out. I can select them and ungroup. But how can I just select the peanut or the hat and legs and such. If I could keep it in color I could just select which color I wanted cut when I go to the cutter right? http://www.brandsoftheworld.com/search/115430737/205971.html Share this post Link to post Share on other sites
jhelms 5 Posted December 16, 2009 Rock the easiest way I found mine came up all black I went in and done WIREFRAME and it brought up all lines and I changed colors there give it a try jhelms Share this post Link to post Share on other sites
rock jeep 1 Posted December 16, 2009 I'll try it....Thanks! Share this post Link to post Share on other sites
rock jeep 1 Posted December 16, 2009 Once I get the outline is there a way to fill an area with a color. Kinda like you do on paint in windows. Share this post Link to post Share on other sites
rock jeep 1 Posted December 17, 2009 Rock the easiest way I found mine came up all black I went in and done WIREFRAME and it brought up all lines and I changed colors there give it a try jhelms How do I change the color? I still havent figured that part out. Share this post Link to post Share on other sites
Jay2703 704 Posted December 17, 2009 select an element then select the color you want to change it to at the bottom of the screen. Jay Share this post Link to post Share on other sites
jhelms 5 Posted December 17, 2009 Also once you change the colors the way you want them then go back and hit wireframe again and it will change everyting back solid jhelms Share this post Link to post Share on other sites
Jay2703 704 Posted December 18, 2009 It should come in in color. I can't even get it to import into SignBlazer. It just comes up blank. I got it to work by inserting the .eps picture into a word document then copy and paste to SignBlazer. There is a lot of cleanup to be done to make it cuttable though. Jay Mr_Peanut.EPS Share this post Link to post Share on other sites
rock jeep 1 Posted December 18, 2009 Thanks guys I will try that stuff tonight. Share this post Link to post Share on other sites
