LOBO
Want to cut Directly from Corel Draw X4... any step by step instructions??
does anyone or can anyone give step by step instructions on setting up to cut directly from corel draw x4....
i've looked but cant find any..
I have OS Vista... LP24..  and Corel Draw X4...
thanks for the help in advance..
ex.. how do i set up the cutter, corel... and do i set up the cutter as a printer.. saw that somewhere..
Sorry you cant use the LP24 as direct PRINTER DRIVER FROM WINDOWS.
You have to use programs like Signcut or Cocut which are plug-ins to print direct from Corel and Adobe and inkscape.
See the new bie manual in the instructional section.
Only Helo, Rabbit and some OEM REFINE plotters have a regular printer driver for windows.
Paco
Lobo, I have a shortcut button that makes things a bit easier. It is a button you can dl from Corel x4 so when you click on it it will then open cut studio for me. Did you see that option when you dl Corel?
