______ 0 Posted November 10, 2009 I havent been doing a lot of cutting the last month and I keep my cutter unpluged when Im not using it, Well I just walked to get a few little things done and she will not power up at all. I used 3 outlets checked the fuse the ground and the power cable nothing is showing any signs of defect PLZ HELP Thank you Share this post Link to post Share on other sites
YadirellT 0 Posted November 10, 2009 Have you checked your switch? Make sure all the connections are secure? Beyond that, I wouldn't recommend doing anything more unless you're an electrician. If that's the case, then please go to support.uscutter.com and submit a ticket. Share this post Link to post Share on other sites
______ 0 Posted November 13, 2009 I checked over everything with a DMM it was the power cable.... Couldn't tell you how that happened but in any case its all good now thanks Share this post Link to post Share on other sites
