MikeWire 0 Posted November 8, 2009 Ive searched and found nothing, and I'm sure this is an easy problem. I am creating text in Illustrator and copy/paste into SB Elements. In Illustrator the text is aligned and looks fine, but when I paste into SB the letters are then grouped and stacked on top of each other. What am I doing wrong, and what can I do to fix it? Share this post Link to post Share on other sites
Jay2703 704 Posted November 8, 2009 Instead of Copy/Paste, save the file as an .eps file then import it into SignBlazer. Jay Share this post Link to post Share on other sites
MikeWire 0 Posted November 8, 2009 Instead of Copy/Paste, save the file as an .eps file then import it into SignBlazer. Jay Thanks Jay, I should have mentioned I have tried that and when I do that the font is not the same as what I am using in Ill. So, I'm still in the same boat. Any ideas? Share this post Link to post Share on other sites
xstreme 0 Posted November 8, 2009 Try converting it to curves and import the .ai file full post script Share this post Link to post Share on other sites
MikeWire 0 Posted November 8, 2009 Try converting it to curves and import the .ai file full post script Hey, this worked perfectly! Thank you! Share this post Link to post Share on other sites
xstreme 0 Posted November 8, 2009 Np. I had the same issue a while back and drove me nuts. Glad I acould help. Share this post Link to post Share on other sites
