paulzeee
PCUT and stand issues
I bought a PCut and it came with this stand:
I think the brackets are drilled wrong cause there are two issues with them.
- The provisions on the bracket where the cutter mounts dont line up
- The provisions on the bracket to mount to the stand dont line up
If the bracket is mounted like this:
...on the outside, the roller is too short.
If the bracket is mounted the other direction (like the directions show), on the inside of the stand then the rollers are too long (if i redrilled the bracket this could be a work around)
anyone else have this issue?? I called PCUT and their support wasn't the best.
Yes. I'm either reading something wrong or the brackets are drilled wrong.
I've tried every combination i could think of.
am I looking at something  wrong?,  you do have the rollers at the back of the machine don't you. ?  They do not go to the front.    They should be behind your machine..  maybe picture not real good angle,  hard to tell
I think the holder arms need to go inside of the vertical support legs. Looks like you have them on the outside. Could you have the vertical supports turned 180?
paulzee,
Look at the pic I supplied.
The cutter mounting brackets are on the inside of the uprights. The roller holding arms stick out the back and cutter faces forward.
Gotcha, when i get home ill take pictures of them mounted like that as well. Even with them mounted on the inside of the stand there are still issues.
hey paulzeee ,
don't know whether this will help at all but ive attached the pic of my p-cut 1200 stand and maybe this will shed some light on things. and dont worry i spent an hour and a half just trying to put the stand together when i first got mine and it took a gentle persuasion to get it to fit (if you get my drift ) so im not surprised to here that your having probs
pete
Thanks for those pictures guys! I finally figured it out. I had the legs backwards....
If you look closely there is a side with a wide channel and a narrower channel. The narrow channel faces in making the bracket mount closer to the legs allowing everything to fit.
Now im waiting for vinyl and im sure ill need more help.
Thanks again y'all
ahhhhh yes! I see exactly what you mean.
Great photos by vinyl tree.
Glad you got it figured out paulzeee!  ;D
[shadow=red,left]thank god [/shadow] ....... some one else stuff up and put the legs on the wrong way ...lol i thought it was only me that did that type of stuff
