tammylynn49459
Saving graphics
As far as what version of inkscape it says inkscape 0.46 at download sight all it says on my desktop is just inkscape. now the last pic that was blurry (sorry) does not give a image type ,we have tried many different images even just tried to draw a straight line and it did the same with that as it has with everything else did not give a image type on the saved icon.
ok,  now that last image that you have up in the picture...  Is that the image that is left on your inkscape screen after you save as an .eps?
Can you show screen shots of trying to import into your Sign Blazer?
also on that picture ending in 44  you should have   .eps added  at the end ..... on that NAME of your file.  at the very top I can't read it very well it looks like it says Peeing  it should have  .eps  after that
i would show a pic of the sb import but in lies the problem when i open sb import and go to my grafix folder it will show every file in there exept the ones i have tried to do. its like there not even there and im starting to think they arent . I think that it is just a name on an empty file because there is no file extension listed  and all the files i have that work have a proper file extension listed.
have you tried doing a search on your computer for 1 of those exact files that you did in inkscape?  Maybe it is going into a totally different folder.  Just go to your START up button on your computer and start search. Look through all your computer,  files, documents. etc.  It has to be going somewhere.
first of all I would like to greatly thank every one for there help it is nice to know there is help out there. we have got everything working , inkscape was not completing file switch to eps and was just giving a shell file. we down loaded a new inkscape and worked right away. should have done it sooner (live and learn i guess) but i believe all is well now.  Again THANK YOU to everone you were all very helpfull.
