ASD123 0 Posted October 10, 2009 Need help resolving an issue I am having with my t-shirts. I am using siser vinyl on pre-washed shirts and using heat press at 350 degrees. After wash and drying, the lettering peals off.. Am I missing a key step in ensuring the vinyl sticks on the shirt? Please Help!!!! Share this post Link to post Share on other sites
Charles Pratt 0 Posted October 10, 2009 Have you checked to make sure the temp. really is what you have it set on with a laser? Also, is your pressure where it needs to be? Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted October 10, 2009 are you pre-pressing teh shirts to remove moisture before applying at 305 for 20 seconds? Share this post Link to post Share on other sites
ASD123 0 Posted October 10, 2009 Well, I am new to this and I have adjusted the temp and found that at 350, my vinyl sticks. I have also adjusted the press to where it is pressing as firm as possible. I will try adjusting the temp again to see if that will resolve my issue. I have heard about putting a piece of Teflon between the press and the vinyl.. Would that make a difference? I will also heat press the shirts to try and remove moisture to see if that makes a difference. Will post results later today, wish me luck... Share this post Link to post Share on other sites
Guest fivestar Posted October 10, 2009 What is the name of your press? Share this post Link to post Share on other sites
ASD123 0 Posted October 10, 2009 I have an XMTD - 708 heat press. Share this post Link to post Share on other sites
Guest fivestar Posted October 10, 2009 Never heard of that press. Sounds like a chinese made press so I would get an infared thermometer and check your upper platen's temperature. Sounds like it's not heating properly. Share this post Link to post Share on other sites
Can-Am 1 Posted October 11, 2009 350 Deg is way over temp. Also make sure you are in F and not C What I do is 18 Sec at 320 , peel backing off and then repress with teflon sheet for 4 sec to ensure nothing loosened during peeling. Pressure at max on the press. We havent had any vinyl peel off in over a year using this method. Share this post Link to post Share on other sites
Renegade 2 Posted October 12, 2009 You have a press problem. Share this post Link to post Share on other sites
Eclipelee 0 Posted November 12, 2009 I use a sgweegie to press across my image and it seems to work great. I would tell you that increasing heat in increments works too!!! Share this post Link to post Share on other sites
sarconastic 29 Posted November 12, 2009 Pressure..........If your confirm your temps are right you need more pressure. What I found with my Chinese press was that to get the appropriate pressure, I basically have to bottom out the springs on top of the platen to get the right amount of impression into the shirt. Kevin Share this post Link to post Share on other sites
Brandon_Davis 1 Posted November 12, 2009 Sarconastic... Any other sage like advice you could offer about pressing vinyl with a Chinese cutter ? Share this post Link to post Share on other sites
DTFuqua 0 Posted November 12, 2009 Yea, Throw it away and get a good one Share this post Link to post Share on other sites
Guest fivestar Posted November 12, 2009 Yea, Throw it away and get a good one ROFLMAO.......I was writing the exact same thing. Share this post Link to post Share on other sites
desertdog10 0 Posted December 8, 2009 Don't give up yet- I had the same problem and stumbled across my problem. I found that the aluminum base was slightly warped and the front and back touched before the middle did- so any amount of pressure wan't going to get the center (the part you need) to have good pressure. You can easily test this by taking a good quality carpenters square and placing it on the base (after removing the pad) and see if you have any gaps. Since I don't have tools to file down aluminum, what I did was place a 11x11 inch 1/4 inch thick square of wood paneling under my 15x15 inch pad in the center. The ensures that the center (where I place the vinyl) will have the greatest pressure. Eventually I will just replace the press but this is what my issue was. I completely understand your pain and frustration!!!! I was just convinced that it was NOT possible to get a good stick with vinyl. Now I know better. -Jeff Share this post Link to post Share on other sites
