atoc 0 Posted September 20, 2009 Had to change computers. Went from Windows XP to Vista. When sent graphic to cutter, it was way too large. Any suggestions? Thanks for any help, Dick Share this post Link to post Share on other sites
mars 45 Posted September 20, 2009 I'm no expert, but I have had size of cut not be what I expected - check to see if your cutter is set up on mm or inches. Which are you designing in? Do they match? My problem was I was designing (in SBEset to mm ) - I was thinking it was set up in inches and a 9 inch graphic cut tiny (9mm) and too small to weed. Changed this setting (top left corner of SBE) Resized my image and all was right with the world - well the vinyl cutting part at my house at least. What program are you using? There ARE some experts on this forum and one of them will be along in a while -- good luck and welcome to the forum -Mike Share this post Link to post Share on other sites
atoc 0 Posted September 20, 2009 That's not the problem as both are set up in inches. What should be a 2" graphic cuts out at about 10". Thanks for your help though. Dick Share this post Link to post Share on other sites
mars 45 Posted September 21, 2009 Glad to try - wasn't much help since it didn't help - sorry. Still don't know what software you are using - may help get an answer for you from somebody familiar with the ins and outs of your software. Any details you can provide may jog somebody's memory. -Mike Share this post Link to post Share on other sites
atoc 0 Posted September 21, 2009 Thanks I am using Coerl x4 and Sign Cut 2 Share this post Link to post Share on other sites
mars 45 Posted September 21, 2009 I'm not much help on either of these - you will probably get a quicker response if the problem is software related by making your request for help known in the Signcut and Corel Draw sections -- I am making a post pointing to this topic under both of those to see if anybody knows what you need to do. -Mike Share this post Link to post Share on other sites
mars 45 Posted September 22, 2009 Look at this topic http://forum.uscutter.com/index.php/topic,21879.0/topicseen.html Send a screenshot to the signcut topic and maybe you will get an answer -Mike Share this post Link to post Share on other sites
mars 45 Posted September 26, 2009 http://forum.uscutter.com/index.php/topic,21879.0/topicseen.html Kimon posted to the topic at the link above with some suggestions and if all else fails a link to open a support ticket. Have a look. Did you get the problem resolved already? -Mike Share this post Link to post Share on other sites
mars 45 Posted September 26, 2009 http://forum.uscutter.com/index.php/topic,20945.0.html Also see this post - if the problem is in signcut here is where you get help the fastest. -mike Share this post Link to post Share on other sites
atoc 0 Posted September 28, 2009 Thank's Everyone Sorry to take so long to get back. I FIXED IT! All I had to do was to use the calibrate button. Don't know how it got off but now it works fine. Thanks Again Dick Share this post Link to post Share on other sites
