b8studio 0 Posted August 30, 2009 hello i have a refine mh1351 ans when i want to cut a circle for example, the cutter starts to cut the circle and it doesn't stop where it started to cut. there is always 1mm of difference... it s ennoying when i do that with small texts...any suggestions? need to change the speed? or else? thanks Share this post Link to post Share on other sites
cutme 5 Posted August 30, 2009 have you calibrated the x,y, on the machine? is your blade offset correct? (0.25) bb Share this post Link to post Share on other sites
b8studio 0 Posted September 1, 2009 how can i calibrate the cutter? andd the blade offset? thanks Share this post Link to post Share on other sites
cutme 5 Posted September 1, 2009 if you have a pen, put it in place of the blade and set your blade offset to "0". in your drawing software (whatever program you use to edit graphics for cutting), draw a square as big as you can draw on whatever paper you have handy (just make sure it is a square). draw the square using your plotter and measure the square on the paper. it should measure the same as the square in the drawing on your computer. if they don't match, make adjustments on your plotters x and y figures, and redraw the square until they do match. don't forget to reset your blade offset when you reinstall the blade. bb Share this post Link to post Share on other sites
