b8studio
mh1351 - precision problems
hello i have a refine mh1351 ans when i want to cut a circle for example, the cutter starts to cut the circle and it doesn't stop where it started to cut.
there is always 1mm of difference... it s ennoying when i do that with small texts...any suggestions? need to change the speed? or else? thanks
have you calibrated the x,y, on the machine? is your blade offset correct? (0.25)
bb
if you have a pen, put it in place of the blade and set your blade offset to "0". in your drawing software (whatever program you use to edit graphics for cutting), draw a square as big as you can draw on whatever paper you have handy (just make sure it is a square). draw the square using your plotter and measure the square on the paper. it should measure the same as the square in the drawing on your computer. if they don't match, make adjustments on your plotters x and y figures, and redraw the square until they do match. don't forget to reset your blade offset when you reinstall the blade.
bb
