becky1233 0 Posted August 24, 2009 I need to convert text to curves in corel x 4. I cannot figure out how to do it. i need to cut it in SB. Thanks in advance. Becky Share this post Link to post Share on other sites
Guest oldthredz Posted August 24, 2009 you can do it in sign blazer just high light the text and press "R" Share this post Link to post Share on other sites
becky1233 0 Posted August 24, 2009 Cool... Thank you! Share this post Link to post Share on other sites
CRD 9 Posted August 24, 2009 In X4 Selec the letters (fonts) and press Control + Q. Done If you have letters spread in layers put all in one layer and convert them from there. Control+A does not work (in my case) for making all objects including letters in to curves. Cheers, Paco Share this post Link to post Share on other sites
MGOMEZ 0 Posted August 24, 2009 you can convert to curves with the arrange menu in coreldraw x4 also. select the text you want to convert and click on arrange and click on convert to curves. Share this post Link to post Share on other sites
jeremySI 18 Posted August 25, 2009 do you need to convert to curves? i just have always typed up the text and cut it like that. Share this post Link to post Share on other sites
edge 67 Posted August 31, 2009 do you need to convert to curves? i just have always typed up the text and cut it like that. No as you have proven it is not necessary in all applications, however my belief is it will cut cleaner when converted. Share this post Link to post Share on other sites
