Tempted Graphics 0 Posted August 8, 2009 Can I use to redesign an image in PDF form I need to make this look better, what can I use. kmartin.pdf kmartin.pdf Share this post Link to post Share on other sites
haumana 1,221 Posted August 8, 2009 I would export it as some kind of graphic file (.tif, .jpg, .png, etc.), then retrace on a different layer in a graphics program (Corel Draw, Fireworks, Illustrator, etc.). Unless they want the "hand drawn" look, then I would just vectorize it and go. post in your signature ... cutter model, operating system, and cutting software - you'd find you'd get quicker and better responses. because if you're using SBE, you can easily export .pdf to .jpg, then import to SBE and trace it. kmartin.SBD kmartin.SBD Share this post Link to post Share on other sites
Tempted Graphics 0 Posted August 8, 2009 I must be a total retard i tried everything to change it and send to SBD I wanna keep it as a PDF when done If you know how that can be done let me know I need to keep it from SB, I am doing these for shirts using a Roland SC-540V, and no SB on the comp for it so I need to keep the PDF Share this post Link to post Share on other sites
Tempted Graphics 0 Posted August 8, 2009 I tried it and everytime it will open in Adobe and then I cannot do Jack-S**t with it there and I could not export it at all I just need them so they can go in to Corel or something I can clean them in besides SB and that is my issue as of now and it is drivin me insane Here is what I have yet kmartin.pdf kmartin4.pdf kmartin5.pdf kmartin6.pdf kmartin.pdf kmartin4.pdf kmartin5.pdf kmartin6.pdf Share this post Link to post Share on other sites
Tempted Graphics 0 Posted August 8, 2009 .......... scan0009.pdf scan0009.pdf Share this post Link to post Share on other sites
Tempted Graphics 0 Posted August 8, 2009 I would export it as some kind of graphic file (.tif, .jpg, .png, etc.), then retrace on a different layer in a graphics program (Corel Draw, Fireworks, Illustrator, etc.). Unless they want the "hand drawn" look, then I would just vectorize it and go. post in your signature ... cutter model, operating system, and cutting software - you'd find you'd get quicker and better responses. because if you're using SBE, you can easily export .pdf to .jpg, then import to SBE and trace it. By the way that looks awesome, you do awesome work when figuring this stuff out, I know I am making it hard than it is, but cannot discpher why Share this post Link to post Share on other sites
midwaste 4 Posted August 8, 2009 If you open it in Illustrator, you can modify all the elements. Attached in .eps, you can do some node editing in SB or whatever program you have. kmartin.eps kmartin.eps Share this post Link to post Share on other sites
