badgersr 0 Posted August 3, 2009 Basically I have a 4ftx8ft sheet and need to cut 40 inch letters, i have a 24 inch plotter. How do you splice or setup SB to do that? Or how do you cut oversized images?? Share this post Link to post Share on other sites
Jay2703 704 Posted August 3, 2009 In your cutter window select settings. Make surre that your vinyl is set for the width you intend on cutting. Set the Tile Overlap (how much two peices will lay on top of each other) to where you want it. Make your design the size you want and when you go to cut, SignBlazer will tile the vinyl for you. Just select which tile you want to cut. Share this post Link to post Share on other sites
