clockman 0 Posted October 11, 2007 I am using Sign Blazer elements and am afraid that the 'weld' option is not usable in this version. I can not seem to get weld to work. I have several different elements that I need to be cut as one piece but they are going to be cut as a bunch of small individual items. Is there some way of connecting these? Thanks, David Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted October 11, 2007 To get weld to work you need to select two or more items you want to weld together and then select the menu "Arrange" - "Weld" - "Total Weld". It is enabled for the SignBlazer Elements version. Share this post Link to post Share on other sites
clockman 0 Posted October 11, 2007 Thank you for the reply. I have downloaded the manual for the software but have not had a chance to look it over fully. I assume that I select more than one object by hitting the 'shift' button, this works with other programs I have. Thanks for answering this newbie's questions! David Share this post Link to post Share on other sites
