camillekindle 0 Posted June 22, 2009 I dont understand what I am doing wrong but everytime I try cutting this file there are random cuts EVERYWHERE and my cutter starts making all kinds of crazy noises. I have cut several other things throughout the day with no problem but this file has been kicking my butt since yesterday. texas1.SBD texas1.SBD Share this post Link to post Share on other sites
Jay2703 704 Posted June 23, 2009 I would start with looking at the Longhorn heads. Each one has hundreds of nodes. That is why your machine is making all of the strange noises. It has to compute a path between each node. Go into SignBlazer and Arrange + Split objects. It will seperate your Texas into two peices and make each of your Longhorns into seperate elements. Pick one to simplify by using Node Edit and remove as many un-needed nodes as possible. Then you can figure the spacing and duplicate the simplified one. (1.14 vertical and .93 horizontal.) Then try it again. Share this post Link to post Share on other sites
Jay2703 704 Posted June 23, 2009 I tried on this one. texas1.SBD Share this post Link to post Share on other sites
camillekindle 0 Posted June 23, 2009 don't worry little lady, your husband has come to the rescue and fixed it. Share this post Link to post Share on other sites
