rpostlewait 0 Posted June 8, 2009 I am new to this forum and using sign blazer and the vinyl cutter. i have a PCcut and use sign blazers. I have some art work in EPS format and I would like to modify them (add names) but I am unable to do this. Any suggestions? Thanks Share this post Link to post Share on other sites
Jay2703 704 Posted June 8, 2009 You can import most .eps files to SignBlazer. Once imported you can modify them using the Node Edit tool. Share this post Link to post Share on other sites
rpostlewait 0 Posted June 8, 2009 Thanks for the quick response. i have tryed to save them as an eps using inkscape but it will not save as an eps. i am sure i am doing something wrong I would appreciate as much instruction as you can give. thanks Share this post Link to post Share on other sites
Jay2703 704 Posted June 8, 2009 Can you post one of the files you are trying to convert? Click on "Additional Options" and browse to the file. Must be less than 500KB Share this post Link to post Share on other sites
rpostlewait 0 Posted June 8, 2009 I will post one once i get home. Thanks Share this post Link to post Share on other sites
rpostlewait 0 Posted June 8, 2009 I would like to add names and departments but I dont know how. Any help would be appreciated. Thanks 34318K.AI 34318K.AI Share this post Link to post Share on other sites
Jay2703 704 Posted June 8, 2009 1. Open SignBlazer, File + Import. 2. Browse to where your file is and select it. Click OK. 3. Select the "Use Postscript Printer" option. Note: All of your graphic doesn't show up on mine but it is there. If you go to View and select Outline/Wireframe you will be able to see it all. Now go back and uncheck this option. 4. Edit + Select All. 5. Arrange + Combine Now you can add your text: 1. Select the text function 2. Select the font you like and an appropriate size 3. Click on the work area to locate your text (you can move, resize and edit later too) 4. Type your text That is all there is to it. Share this post Link to post Share on other sites
