Redsfan 0 Posted May 26, 2009 Hi Everyone,Could surely use some help in choosing the best software for my new pcut. Adobe Illustrator, Inkscape or Corel Draw9 and what version) I'm am clueless ! Share this post Link to post Share on other sites
Guest fivestar Posted May 26, 2009 I use Corel Draw X4. Inkscape is free so I'd download that if I was you and start messing with it. Share this post Link to post Share on other sites
Knehmer 0 Posted June 8, 2009 Are you able to cut with the PCut directly from x4? Share this post Link to post Share on other sites
CRD 9 Posted June 10, 2009 No, From X4 save as eps and import in SBE or other program. Only from Signcut Pro you can use the plugin to auto convert to cut by one click. But some seem to have al kind of weird problems. At my side it works perfect now. Paco Share this post Link to post Share on other sites
Guest sciondrgn Posted June 10, 2009 I use the Free Inkscape and FlexiSign. So far I've been able to do everything in those two without having to go to Illustrator or anything else. FlexiSign is a good all in one program that lets you design and cut Share this post Link to post Share on other sites
tlzimmerman 11 Posted June 10, 2009 I am using Inkscape and a 2nd hand copy of Flexi I came across. I have used AI and Corel X3 both to design with....and I keep coming back to inkscape. Corel an Illustrator are more powerful for all aspects of vector design, but for vinyl cutting design I can run circles around them using Inkscape. Everyone is different but I love it, haven't found one thing I can't do faster in Inkscape than Illustrator or Corel, in fact the only time the other 2 get opened is to open an eps and save it as an SVG so I can open it in Inkscape and edit it and then resave it as EPS to cut. Thats the only drawback is Inkscape will not open and edit an EPS natively, but it will save it that way so you can import and cut. Share this post Link to post Share on other sites
