palko1 0 Posted May 22, 2009 Hi. I'm using an ibook g4 (non intel) and system 10.4.11. I had the cutter working fine but now it's not communicating with the p-cut 630. I checked the settings and noticed nothing was selected in the device pull down. I had this problem before and called tech support. They said select tcp/ip. I did that and it worked fine. But this time when I select it, it ask for an IP:. It didn't do that last time. I don't know what to put there so I left it blank. Still doesn't work. Tried calling tech support but no answer. Waiting for them to call me back. Any suggestions? Thanks. Rich Share this post Link to post Share on other sites
kenimes 42 Posted May 26, 2009 I thought the Device selection should look like /dev/cu.USBSerial00000, when using the PCut USB cable to connect to your Mac. Share this post Link to post Share on other sites
