TwistedCreations
Using Plotter Feature to Create Wargame Grid Maps?
I was considering buying a US Cutter Raindrop for my hobbies. But after a few conversations here, I have been persuaded to look at larger models.
One reason I was thinking of going with a larger unit, like a 50" Refine was to make grid terrain maps for miniature wargames.
My friends and I like to make up very large battles. The games are played on a "map" that is blocked out in a one inch by one inch grid.
I was wondering if you could use the plotter feature and print out a 1 X 1 grid on banner material (or something like it) in a 4' by 8' size.
The maps look like this...
The plotter would only be used to print the 1 X 1 grid, not the underlying images.
A game board the size of a full sheet of plywood would be amazing!!
Do you think that this is possible?
If not, do you have any suggestions?
Thanks so much for your time and help!
- Marc
Guest fivestar
If you're talking about just 1 sq in boxes then yes it should do it no problem.
Thanks for the reply!
What about drawing it on banner material?
Do you think that is a good material to make it on?
I see you live in Ohio. Where abouts?
I live in Akron.
Guest fivestar
I honestly don't know about drawing it on banner material.  I'd say you could of you could find a sharpie or something the wouldn't smear.
I am in Caldwell, straight down I-77 exit 25.
