Kysmiley 0 Posted April 1, 2009 I see that I have a ground cord connected to the bottom of the MH 721, where does the other end hook to? Pat Share this post Link to post Share on other sites
tlzimmerman 11 Posted April 1, 2009 Any screw on the stand....also you may want to make sure you outlet is grounded....if it isnt i would suggest either grounding it or running a separate ground wire to your cutter from a water pipe or another good source of ground. Share this post Link to post Share on other sites
Kysmiley 0 Posted April 1, 2009 Thank-you once again. I was going to do that but wanted to make sure first it would be ok. Share this post Link to post Share on other sites
