Kysmiley
ground cord
I see that I have a ground cord connected to the bottom of the MH 721, where does the other end hook to?
Pat
Any screw on the stand....also you may want to make sure you outlet is grounded....if it isnt i would suggest either grounding it or running a separate ground wire to your cutter from a water pipe or another good source of ground.
