biggin69
How to round corners on a square?
Worked for me thanks for the info FBR
there are options for the circle maker too
I was doing a node edit to round corners this will be a great time saver
thanks again
I tried this too and couldn't get it to work right. I adjusted the different settings and it still makes a square box. Maybe a little more info from someone.
Like is I want a box 5" x 5" with rounded corners, what are your settings in there?
Thanx
Kevin
NEVERMIND..... ;) I figured it out. I was Adjusting everything in the box after I right clicked but not clicking OK, just clicking back on the desktop. Most pop up tool bars, you adjust your setting s and then click where you want it. Just another learning curve issue.
