aspman 0 Posted March 29, 2009 Hi Guys, Got the computer and software installed fine with the cutter. My question is, I think it needs to cut a little deeper, it is hard to weed. I have the down pressure set at 120. Should I keep trying to increase the pressure or are there some other settings i should be looking at?? Seems like other posts i had read were saying less down pressure than what i have it at now?? Also it came with the signblazer software and when i fill out the reg info on the reg screen it says it will send me an email with a registration number. I have not recieved it. Also it tries to to an update and says it cant connect to the server. My internet connection is good i can browse web and send email fine. Any Ideas??? Thanks Kerry Share this post Link to post Share on other sites
Guest fivestar Posted March 29, 2009 Extend the blade out a little bit more and decrease the pressure. As for Sign Blazer, they went out of business after the owner pased away so you will use it in "demo mode" but it works the same as registered mode. Share this post Link to post Share on other sites
