hauser 0 Posted February 18, 2009 got a new laptop with vista prem/sp1 i just can`t get signblazer to work.i tried compatibilty mode to run as administrator.your ask to try the program.it will run one time.the next time you get a error=2 can`t run live update.have no idea what to do next.any help i would be very greatful for...some days you just can`t win.. Share this post Link to post Share on other sites
Cre8tiveCutter 7 Posted February 18, 2009 there is also a way to stop that update from popping up, someone else will help you with that or do a search the directions are here in the forum. Helped me out greatly! There is no update so you have to stop it. Renee Share this post Link to post Share on other sites
Jay2703 704 Posted February 18, 2009 In the shortcut you use to start SignBlazer change the target from SB.exe to SBNT.exe. Share this post Link to post Share on other sites
hauser 0 Posted February 18, 2009 :laugh:you people are just great!!!!!!!this is what i had to do for program to work..did what you said changed target from sb.exe to sbnt.exe...to do this you have to right click on short cut,then on bottom open properites goto compatilbilty at bottom check run as administraror in the privilege level then click apply.restart computer.oh to change target you must do that in the properites tab. thanks a bunch people Share this post Link to post Share on other sites
