aries58 0 Posted February 2, 2009 I did a cut and nothing came out but cut box? 008e_1.eps 008e_1.eps Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 There are no paths to cut. you can save an image as an .eps and all that will do if you send it to the cutter is cut a box the size of the image. Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 here are no paths to cut. you can save an image as an .eps and all that will do if you send it to the cutter is cut a box the size of the image. What do you mean?I can see the graphic? Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 yes, and i can to, but when you select the image, there are usualy red lines that follow the edges. these red lines are the paths that the blade follows when its sent to the cutter. where did you get the image from? Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 try this one. import this one and import yours and look at them side by side. you'll notice one has lines to designate where the cutting path will be. trailrider.eps trailrider.eps Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 try this one. import this one and import yours and look at them side by side. you'll notice one has lines to designate where the cutting path will be. This one doesn't show in my sb workspace to see? Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 are you using the open feature or the import feature? Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 are you using the open feature or the import feature? Import Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 do you get an error message or you just dont see it? Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 do you get an error message or you just dont see it? no error Share this post Link to post Share on other sites
Jay2703 704 Posted February 2, 2009 The file you are trying to import is a .eps file but it is in Raster format. Just because a files is .eps does not mean it is cutable. This is just a .bmp that has been saved as a .eps file. Share this post Link to post Share on other sites
mac6986 93 Posted February 2, 2009 The file you are trying to import is a .eps file but it is in Raster format. Just because a files is .eps does not mean it is cutable. This is just a .bmp that has been saved as a .eps file. mine or his? Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 The file you are trying to import is a .eps file but it is in Raster format. Just because a files is .eps does not mean it is cutable. This is just a .bmp that has been saved as a .eps file. it was bmp,I mono chrome it,then vectorised it in sb.the one i posted.. Share this post Link to post Share on other sites
Jay2703 704 Posted February 2, 2009 Aries, (I was referring to your original .eps file.) you must have vectorized the .bmp then deleted the vector instead of the original .bmp file. All that is there is the .bmp. Another possibility is that the .bmp was selected when you exported it. The default mode in export is "Selected". Then only the selected elements get exported. Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 Aries, (I was referring to your original .eps file.) you must have vectorized the .bmp then deleted the vector instead of the original .bmp file. All that is there is the .bmp. Another possibility is that the .bmp was selected when you exported it. The default mode in export is "Selected". Then only the selected elements get exported. Thanks..I did the remove bmp and keep in sb.Maybe I posted wrong file got so many where i been playing with them.. Share this post Link to post Share on other sites
Jay2703 704 Posted February 2, 2009 Post the SignBlazer file too. Share this post Link to post Share on other sites
aries58 0 Posted February 3, 2009 Post the SignBlazer file too. Here is orginal jpg maybe you can vector it for me Please.. Share this post Link to post Share on other sites
Guest stunad, jr. Posted February 3, 2009 try this one. maybe easier for you trailrider.SBD trailrider.SBD Share this post Link to post Share on other sites
aries58 0 Posted February 3, 2009 try this one. maybe easier for you I can't save either file..on the jpg i get a error,on the sbd it goes nowhere.. Share this post Link to post Share on other sites
Jay2703 704 Posted February 3, 2009 try this one. maybe easier for you I can't save either file..on the jpg i get a error,on the sbd it goes nowhere.. Are you clicking on Trailblazer.sbd and selecting "Save" to save it to your hard drive? Share this post Link to post Share on other sites
aries58 0 Posted February 3, 2009 try this one. maybe easier for you I can't save either file..on the jpg i get a error,on the sbd it goes nowhere.. Are you clicking on Trailblazer.sbd and selecting "Save" to save it to your hard drive? Yes got it now but psp9 won't open it.see nothing when i open in sb.. Share this post Link to post Share on other sites
aries58 0 Posted February 3, 2009 try this one. maybe easier for you I can't save either file..on the jpg i get a error,on the sbd it goes nowhere.. Are you clicking on Trailblazer.sbd and selecting "Save" to save it to your hard drive? Share this post Link to post Share on other sites
